Ana içeriğe geç
Dell Chromebook 11 3189 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Chromebook 11 3189 Display Assembly Replacement, Replace the Display Hinge: adım 1, 1 resimden 1.
    • Lift the display assembly away from the computer.
  2. Dell Chromebook 11 3189 Display Assembly Replacement, Place the Display Assembly: adım 3, 1 resimden 1.
    • Place the display assembly to align with the screw holders on the computer.
  3. Dell Chromebook 11 3189 Display Assembly Replacement, Replace the Screws: adım 4, 1 resimden 1.
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  4. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the Sensor Cable: adım 5, 1 resimden 1.
    • Flip over the computer and connect the sensor cable on the system board.
  5. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the Display Cable: adım 6, 1 resimden 1.
    • Connect the display cable to the connector on the system board.
  6. Dell Chromebook 11 3189 Display Assembly Replacement, Securing the Screws: adım 7, 1 resimden 1.
    • Place the metal bracket over the (display cable) connector, and tighten the M2.0x3.0 screws to secure the display cable to the computer.
  7. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the WLAN cables.: adım 8, 1 resimden 1.
    • Connect the WLAN cables.
  8. Dell Chromebook 11 3189 Display Assembly Replacement, Placing the Metal Bracket: adım 9, 1 resimden 1.
    • Place the metal bracket, and tighten the M2.0x3.0 screw to the WLAN cable on the system board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Terrence15
79.161 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
Bir Yorum
Hola, he remplazado la pantalla. El montaje perfecto pero no enciende. Hay que hacer algo en concreto? Me refiero para que detecte esta pantalla nueva.
Muchas gracias
jordi fernandez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 1,827
