Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will display how to replace the battery. A recall was issued on the batteries that came with the Dell Chromebook 11, so it is very important to know how to replace them. A faulty battery may not only be unable to hold a charge, but could also cause severe damage to the device.
  1. Make sure that device is fully powered down before attempting to open the back case. Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver. Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery. Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running. You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
Sonuç
To replace your Dell Chromebook 11 battery, follow these instructions in order.
Bir başkası bu kılavuzu tamamladı.
Jerry Geffrard
322 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 UMass Dartmouth, Team S3-G6, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G6
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 790
