Neye ihtiyacın var
Get your trusty Phillips screwdriver and unscrew the Phillips Screws and put them somewhere safe.
Then pry open and remove bottom case cover.
Now what you want to do is find two screws protecting the battery. Unscrew them and put them somewhere safe.
Remove the cable from the battery and put it somewhere safe.
Now, find the DC Jack Cable. It should be in the top right corner.
To remove the DC Jack Cable, use your fingernails and try to remove it. Once out, put it somewhere safe.
To put in a new one, insert it with a lot of pressure and it should be secure.
To reassemble your device, follow steps 1 and 2 in reverse order.
Bir başkası bu kılavuzu tamamladı.
