Giriş
Scratches or cracks in the screen cover are very common with portable devices. While minor damage can be ignored, anything major will require a replacement since it may harm the rest of the device, and possibly the user.
Neye ihtiyacın var
Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
Locate the two hinges on the corners of the device.
Unscrew the 5 2mm Phillips #00 screws in the hinges.
Pull the hinges up and slide bottom cover out
Locate the seam between the screen cover, and the top panel
Starting at one of the hinge corners, take a thin metal prying tool and gently insert it into the seam.
Gently push the tool down towards the top panel until you feel the screen cover disconnect.
Repeat this process all around the screen cover until it is completely disconnected from the top panel.
