Ana içeriğe geç
Dell Chromebook 11-3120 Battery Replacement
Neye ihtiyacın var
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: adım 1, 1 resimden 1.
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: adım 2, 2 resimden 1. Dell Chromebook 11-3120 Battery Replacement: adım 2, 2 resimden 2.
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: adım 3, 1 resimden 1.
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: adım 4, 1 resimden 1.
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
Sonuç
Dalton D
2.569 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 403
