Giriş
The USB port allows for small amounts of data to be transferred from computer to computer via a USB drive. Sometimes these drives do not connect properly due to a broken motherboard. Here is a guide on how to properly replace the motherboard.
Neye ihtiyacın var
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
Bir başkası bu kılavuzu tamamladı.
