Giriş
The motherboard makes connections to all of the different components of the laptop, allowing for power and data to be transmitted and distributed throughout all of the remaining hardware. In this guide, you will be shown how to remove this portion of your laptop so that the motherboard can be replaced.
Neye ihtiyacın var
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
Using a JIS #0 screwdriver, unscrew the ten 4mm screws securing the motherboard in place.
Gently remove the 3 ribbon cables that connect to the motherboard from other components. Lift the tiny switch from the direction of the wire insertion keeping the ribbon in place and pull the transparent strip attached to the ribbon.
Gently remove the display ribbon cable that says "NON-TOUCH" on its tag. This ribbon cable does not have a locking switch, but there is a wire metal latch that should be lifted up before pulling the ribbon.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Battery removal isn’t necessary. After removing the bottom case, you can skip to step 4 and just disconnect the battery before continuing.
