Giriş
Sometimes speakers or speaker housings can break overtime due to normal wear and tear. In this guide we will show you how to properly remove and replace the speakers.
Neye ihtiyacın var
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
Gently remove the 4-pin connector that connects the speakers to the motherboard.
Bir başkası bu kılavuzu tamamladı.
