Ana içeriğe geç
Dell Chromebook 13-7310 Battery Replacement
Neye ihtiyacın var
  1. Dell Chromebook 13-7310 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Dell Chromebook 13-7310 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Battery Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Battery Replacement: adım 5, 1 resimden 1.
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
Sonuç
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 1,254
