Ana içeriğe geç
Dell Chromebook 13-7310 Cooling Fan Replacement
Neye ihtiyacın var
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: adım 1, 2 resimden 1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 1. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: adım 4, 2 resimden 1. Dell Chromebook 13-7310 Cooling Fan Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
Sonuç
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 501
