Ana içeriğe geç
Dell Chromebook 13-7310 Network Card Replacement
Neye ihtiyacın var
  1. Dell Chromebook 13-7310 Network Card Replacement, Back Cover: adım 1, 2 resimden 1. Dell Chromebook 13-7310 Network Card Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Network Card Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Network Card Replacement, Battery: adım 3, 1 resimden 1.
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Network Card Replacement: adım 4, 1 resimden 1.
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Network Card Replacement: adım 5, 1 resimden 1.
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Network Card Replacement, Network Card: adım 6, 2 resimden 1. Dell Chromebook 13-7310 Network Card Replacement, Network Card: adım 6, 2 resimden 2.
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Network Card Replacement: adım 7, 1 resimden 1.
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Network Card Replacement: adım 8, 1 resimden 1.
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
Sonuç
Brett Raymond
469 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 534
