Ana içeriğe geç
Dell Chromebook 3100 2-in-1 Battery Replacement
Neye ihtiyacın var
  1. Dell Chromebook 3100 2-in-1 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Dell Chromebook 3100 2-in-1 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Battery Replacement: adım 2, 2 resimden 1. Dell Chromebook 3100 2-in-1 Battery Replacement: adım 2, 2 resimden 2.
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Battery Replacement, Battery: adım 3, 2 resimden 1. Dell Chromebook 3100 2-in-1 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Battery Replacement: adım 4, 3 resimden 1. Dell Chromebook 3100 2-in-1 Battery Replacement: adım 4, 3 resimden 2. Dell Chromebook 3100 2-in-1 Battery Replacement: adım 4, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Battery Replacement: adım 5, 2 resimden 1. Dell Chromebook 3100 2-in-1 Battery Replacement: adım 5, 2 resimden 2.
    • Carefully remove the battery from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maria Williams
254 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Pee Fall 2021 Gateway, Team 1-1, Pee Fall 2021 üyesi
GCC-PEE-F21S1G1
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 55
Her zaman: 1,372
