Ana içeriğe geç
Dell DJ Disassembly
Neye ihtiyacın var
  1. Dell DJ Disassembly, Dell DJ Disassembly: adım 1, 3 resimden 1. Dell DJ Disassembly, Dell DJ Disassembly: adım 1, 3 resimden 2. Dell DJ Disassembly, Dell DJ Disassembly: adım 1, 3 resimden 3.
    • Inspect your device and be sure that it matches the device that this guide is disassembling.
    • Familiarize yourself with the specific design of the device.
    • Battery replacement is the only repair that our guide offers that does not require a complete tear down.
  2. Dell DJ Disassembly: adım 2, 3 resimden 1. Dell DJ Disassembly: adım 2, 3 resimden 2. Dell DJ Disassembly: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
    • Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
    • Be sure to keep the 4mm screws together and organized on the device magnet plate.
  3. Dell DJ Disassembly: adım 3, 3 resimden 1. Dell DJ Disassembly: adım 3, 3 resimden 2. Dell DJ Disassembly: adım 3, 3 resimden 3.
    • The top plate of the device is attached by a dot of glue. Use the metal spudger to pry the plate off.
    • After the top plate is removed, remove the four 4mm screws that attach the inner plate.
    • When the plate is removed, the motherboard will be ready to be removed.
  4. Dell DJ Disassembly: adım 4, 3 resimden 1. Dell DJ Disassembly: adım 4, 3 resimden 2. Dell DJ Disassembly: adım 4, 3 resimden 3.
    • Slide the motherboard out of the protective case.
    • Be careful not to snag any wires.
    • When the motherboard is exposed the device is ready to be inspected and repaired.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
William Abel
164 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
How did you get the logic board to slide past the scroll wheel ?
kf4qic - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 596
