Ana içeriğe geç
Dell Dimension 4600 RAM Replacement
Neye ihtiyacın var
  1. Dell Dimension 4600 RAM Replacement, Side Panel: adım 1, 1 resimden 1.
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 RAM Replacement: adım 2, 1 resimden 1.
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 RAM Replacement: adım 3, 1 resimden 1.
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Locate the RAM modules on the motherboard.
  5. Dell Dimension 4600 RAM Replacement: adım 5, 2 resimden 1. Dell Dimension 4600 RAM Replacement: adım 5, 2 resimden 2.
    • Locate the white or black tabs holding the RAM module in place.
    • Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
    • Repeat this for the tab on the other side of the RAM module.
    • Repeat this step for each RAM module.
  6. Dell Dimension 4600 RAM Replacement: adım 6, 2 resimden 1. Dell Dimension 4600 RAM Replacement: adım 6, 2 resimden 2.
    • Grasp the RAM module and firmly pull upwards until it is released from its slot.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Daniel Crawford
1.021 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G10
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Would be great if the DIMM slots were explained (numbering) as to which are populated for dual channel, etc.
MJfromMD - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 10,171
