Giriş
Use this guide to replace a damaged display bezel.
Neye ihtiyacın var
Lay the monitor screen-down so the back screws are exposed.
Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
Locate the two holes on the bottom of the monitor.
Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
Continue prying along the entire edge of the monitor.
5 farklı kişi bu kılavuzu tamamladı.
