Ana içeriğe geç
Dell E193FPc Interface Buttons Replacement
Neye ihtiyacın var
    1. Dell E193FPc Interface Buttons Replacement, Stand: adım 1, 1 resimden 1.
      • Lay the monitor screen-down so the back screws are exposed.
      • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
      FixBot'a Sor
      Yorum Ekle
    2. Dell E193FPc Interface Buttons Replacement: adım 2, 1 resimden 1.
      • Gently lift and pull away the stand at a slight angle away from the monitor.
      FixBot'a Sor
      Yorum Ekle
    1. Dell E193FPc Interface Buttons Replacement, Display Bezel: adım 3, 2 resimden 1. Dell E193FPc Interface Buttons Replacement, Display Bezel: adım 3, 2 resimden 2.
      • Locate the two holes on the bottom of the monitor.
      • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
      • This task is much easier if two people pry simultaneously at each hole.
      • Continue prying along the entire edge of the monitor.
      FixBot'a Sor
      Yorum Ekle
    2. Dell E193FPc Interface Buttons Replacement: adım 4, 2 resimden 1. Dell E193FPc Interface Buttons Replacement: adım 4, 2 resimden 2.
      • When finished prying, the plastic will partially fall away from the rest of the monitor.
      • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
      • While holding the frames together, carefully flip the monitor over so it faces screen down.
      • Gently lift and remove remove the rear case from the monitor.
      FixBot'a Sor
      Yorum Ekle
    3. Dell E193FPc Interface Buttons Replacement: adım 5, 3 resimden 1. Dell E193FPc Interface Buttons Replacement: adım 5, 3 resimden 2. Dell E193FPc Interface Buttons Replacement: adım 5, 3 resimden 3.
      • Locate the green interface button board.
      • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
      • Lift the monitor interior away from the front cover.
      FixBot'a Sor
      Yorum Ekle
    1. Dell E193FPc Interface Buttons Replacement, Interface Buttons: adım 6, 1 resimden 1.
      • Behind the front panel of the plastic cover lies the button strip.
      • Remove the buttons by gently pulling up on the strip.
      • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Charley Grove
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G36
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 2,678
