Ana içeriğe geç
Giriş
Replace the interface buttons if they have fallen out or are worn out from usage.
Parçalar
Hiçbir parça belirtilmedi.
  1. Lay the monitor screen-down so the back screws are exposed.
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Gently lift and pull away the stand at a slight angle away from the monitor.
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  4. Locate the two holes on the bottom of the monitor. Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  5. When finished prying, the plastic will partially fall away from the rest of the monitor. Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  6. Locate the green interface button board. Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel. Lift the monitor interior away from the front cover.
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
  7. Behind the front panel of the plastic cover lies the button strip.
    • Behind the front panel of the plastic cover lies the button strip.
    • Remove the buttons by gently pulling up on the strip.
    • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Charley Grove
95 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G36
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
Her zaman: 1,793
