Ana içeriğe geç
Dell E193FPc Inverter Board Replacement
Neye ihtiyacın var
  1. Dell E193FPc Inverter Board Replacement, Stand: adım 1, 1 resimden 1.
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Inverter Board Replacement: adım 2, 1 resimden 1.
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Inverter Board Replacement, Display Bezel: adım 3, 2 resimden 1. Dell E193FPc Inverter Board Replacement, Display Bezel: adım 3, 2 resimden 2.
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Inverter Board Replacement: adım 4, 2 resimden 1. Dell E193FPc Inverter Board Replacement: adım 4, 2 resimden 2.
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Inverter Board Replacement: adım 5, 3 resimden 1. Dell E193FPc Inverter Board Replacement: adım 5, 3 resimden 2. Dell E193FPc Inverter Board Replacement: adım 5, 3 resimden 3.
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
  6. Dell E193FPc Inverter Board Replacement, Inverter Board: adım 6, 3 resimden 1. Dell E193FPc Inverter Board Replacement, Inverter Board: adım 6, 3 resimden 2. Dell E193FPc Inverter Board Replacement, Inverter Board: adım 6, 3 resimden 3.
    • With the monitor facing down, remove the two 5.81 mm Phillips #2 screws on the right side of the metal casing.
    • With the monitor still facing down, remove the two 5.81 mm Phillips #2 screws on the left side of the casing.
    • Do attempt to pull apart the casing. There are still wires holding the front and back together.
  7. Dell E193FPc Inverter Board Replacement: adım 7, 1 resimden 1.
    • Using a 5 mm nut driver, unscrew the VGA port's mounting screws from the metal casing.
  8. Dell E193FPc Inverter Board Replacement: adım 8, 1 resimden 1.
    • With the monitor facing down, gently lift the back case away from the rest of the monitor to expose the inverter board and mother board.
    • Recall that the casing is still held together by several wires. Do not attempt to fully remove the back casing.
  9. Dell E193FPc Inverter Board Replacement: adım 9, 2 resimden 1. Dell E193FPc Inverter Board Replacement: adım 9, 2 resimden 2.
    • The inverter board is the smaller board in the corner.
    • Remove the three 7.69 mm Phillips #2 screws from the inverter board.
    • Remove the two 7.69 mm Phillips #2 grounding screws from the wire with the black connector.
    • Gently pull the inverter board away from the case. Note that the board is still connected to several components by wires.
  10. Dell E193FPc Inverter Board Replacement: adım 10, 2 resimden 1. Dell E193FPc Inverter Board Replacement: adım 10, 2 resimden 2.
    • There is a wire connecting the motherboard to the inverter board. Squeeze both sides of the connector and pull to remove it from the socket.
    • There is another wire connecting the button board to the inverter board. Remove the second white wire connector.
    • A third wire connects the inverter board to the screen circuit board. Remove the black wire connector.
    • The inverter board can now be fully removed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mackenzie Keane
523 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G36
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 28
Son 30 gün: 82
Her zaman: 5,287
