Ana içeriğe geç
Dell EMC PowerEdge R750 Server Fan Replacement
Neye ihtiyacın var
  1. Dell EMC PowerEdge R750 Server Fan Replacement, Server Fan: adım 1, 3 resimden 1. Dell EMC PowerEdge R750 Server Fan Replacement, Server Fan: adım 1, 3 resimden 2. Dell EMC PowerEdge R750 Server Fan Replacement, Server Fan: adım 1, 3 resimden 3.
    • Gently slide or lift the cover off, exposing the internal components.
  2. Dell EMC PowerEdge R750 Server Fan Replacement: adım 2, 3 resimden 1. Dell EMC PowerEdge R750 Server Fan Replacement: adım 2, 3 resimden 2. Dell EMC PowerEdge R750 Server Fan Replacement: adım 2, 3 resimden 3.
    • Locate the fan(s) within the server.
    • Typically they are located near heat-sensitive components like the CPU or Power Supply. A visual inspection will help identify the malfunctioning fan.
  3. Dell EMC PowerEdge R750 Server Fan Replacement: adım 3, 3 resimden 1. Dell EMC PowerEdge R750 Server Fan Replacement: adım 3, 3 resimden 2. Dell EMC PowerEdge R750 Server Fan Replacement: adım 3, 3 resimden 3.
    • Release the clips holding the fan in place.
    • Keep the screws safe as you may need them to install the new fan.
    • Carefully lift the fan out of its slot. Take note of the positioning to ensure the replacement fan is aligned correctly.
  4. Dell EMC PowerEdge R750 Server Fan Replacement: adım 4, 3 resimden 1. Dell EMC PowerEdge R750 Server Fan Replacement: adım 4, 3 resimden 2. Dell EMC PowerEdge R750 Server Fan Replacement: adım 4, 3 resimden 3.
    • Place the new fan in the same position, ensuring it is aligned as the previous one.
    • Secure it by replacing the screws or clipping it into place.
  5. Dell EMC PowerEdge R750 Server Fan Replacement: adım 5, 3 resimden 1. Dell EMC PowerEdge R750 Server Fan Replacement: adım 5, 3 resimden 2. Dell EMC PowerEdge R750 Server Fan Replacement: adım 5, 3 resimden 3.
    • Now that the new fan is inserted correctly, make a visual verification that all parts look properly placed.
  6. Dell EMC PowerEdge R750 Server Fan Replacement: adım 6, 3 resimden 1. Dell EMC PowerEdge R750 Server Fan Replacement: adım 6, 3 resimden 2. Dell EMC PowerEdge R750 Server Fan Replacement: adım 6, 3 resimden 3.
    • Reattach the server's outer casting and tighten the screws.
    • Plug the server back in, power it on, and listen to the new fan to ensure it is running smoothly.
Sonuç
Kristiana Romero
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 86
