Ana içeriğe geç
Dell G3 15 3579 RAM Replacement
Neye ihtiyacın var
  1. Dell G3 15 3579  RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Make sure the laptop is off.
    • Lay the laptop on its front so the bottom is facing up.
  2. Dell G3 15 3579  RAM Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #0 to remove the eight screws (M2.5x6) on the bottom of the laptop.
    • Use the Phillips #0 to loosen the two captive screws (M2.5).
  3. Dell G3 15 3579  RAM Replacement: adım 3, 3 resimden 1. Dell G3 15 3579  RAM Replacement: adım 3, 3 resimden 2. Dell G3 15 3579  RAM Replacement: adım 3, 3 resimden 3.
    • Use your hands or an opening tool to gently pry the bottom panel off, starting from the left hinge.
    • Continue prying from the bottom to the right side of the back panel and lift it off.
  4. Dell G3 15 3579  RAM Replacement: adım 4, 2 resimden 1. Dell G3 15 3579  RAM Replacement: adım 4, 2 resimden 2.
    • Gently unplug the battery connecter from the motherboard.
  5. Dell G3 15 3579  RAM Replacement: adım 5, 3 resimden 1. Dell G3 15 3579  RAM Replacement: adım 5, 3 resimden 2. Dell G3 15 3579  RAM Replacement: adım 5, 3 resimden 3.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
  6. Dell G3 15 3579  RAM Replacement: adım 6, 2 resimden 1. Dell G3 15 3579  RAM Replacement: adım 6, 2 resimden 2.
    • Gently align the new RAM with the tab on the slot.
    • Then slide it firmly into the slot at an angle and press the RAM down until it clicks into place.
    • If you do not hear the click, remove the RAM and reinstall it.
  7. Dell G3 15 3579  RAM Replacement: adım 7, 1 resimden 1.
    • Align the bottom cover with the slots of the laptop and snap it into place.
    • Tighten the two captive screws (M2.5) to secure the bottom cover.
    • Replace the eight screws (M2.5x6) to secure the bottom cover.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 91
Her zaman: 4,175
