Giriş
If your Dell Inspiron 3542 laptop has stopped or if you just need to upgrade your system with new components, use this guide to replace the motherboard. The motherboard is responsible for overall performance, and your laptop will load a lot faster. If the motherboard stops working, then the entire system will begin to fail, including fans, lights, and more.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Neye ihtiyacın var
Slide the latches on both sides of the laptop outward to unlock the battery.
Remove the battery from the computer.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
Hi. Looking for a compatible motherboard for dell inspiron 15-3542.
eric.mwakibengele - Yanıt
