Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Neye ihtiyacın var
Pop out the rubber pieces and unscrew the 7 screws on the bottom of the computer.
Open the RAM door in the center remove the hidden screw labeled "KB" just above the RAM sticks.
There are two ribbon cables securing the keyboard - data and backlight power. Each ribbon connector must be released by flipping the black retainer up with a fingernail or nylon Uspudger before pulling out the ribbon.
First flip up the black retainer on the smaller connector. Slide the cable up and out of the connector.
Secondly, flip the black connector up on the larger connector. Slide the cable straight out of the connector, parallel to the case.
Remove the keyboard from the case.
3 farklı kişi bu kılavuzu tamamladı.
