Ana içeriğe geç
Dell Inspiron 10z 1120 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 10z 1120 Hard Drive Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 10z 1120 Hard Drive Replacement, Sliding the Hard Drive: adım 2, 1 resimden 1.
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Dell Inspiron 10z 1120 Hard Drive Replacement, Lifting the Hard-drive: adım 3, 1 resimden 1.
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 10z 1120 Hard Drive Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 10z 1120 Hard Drive Replacement, Lifting the Hard-Drive: adım 5, 1 resimden 1.
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: adım 6, 2 resimden 1. Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: adım 6, 2 resimden 2.
    • Place the hard drive in the hard-drive bracket.
  7. Dell Inspiron 10z 1120 Hard Drive Replacement, Replace the Screws: adım 7, 1 resimden 1.
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 10z 1120 Hard Drive Replacement, Placing the Hard Drive: adım 8, 1 resimden 1.
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 10z 1120 Hard Drive Replacement, Replace the Two Screws: adım 9, 1 resimden 1.
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Sonuç
Terrence15
79.243 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 323
