Ana içeriğe geç
Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement, Power Buttons and Volume-Buttons Board: adım 1, 1 resimden 1.
    • Close the computer and turn it over so that the bottom of the computer is facing up.
  2. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: adım 2, 1 resimden 1.
    • Remove the nine 7.6mm PH0 screws on the back cover.
  3. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to remove the cover from the back of the computer.
  4. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: adım 4, 1 resimden 1.
    • Remove the three small 4.7mm PH0 screws that secure the battery.
  5. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: adım 5, 1 resimden 1.
    • Move the hard drive cable away from the battery.
    • You want to make enough clearance to remove the battery without it catching on the hard drive cable.
  6. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: adım 6, 1 resimden 1.
    • Lift the battery up and toward yourself to remove it, revealing the back of the keyboard underneath.
  7. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: adım 7, 1 resimden 1.
    • Disconnect the cable for the power and volume buttons from the motherboard.
    • You may need to use a spudger to remove the cable from the routing guides by the speaker.
Sonuç
Muhammad Erchid
1.051 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Leahy Fall 2018 USF Tampa, Team S1-G6, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 368
