Ana içeriğe geç
Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement, Processor Fan and Heat Sink: adım 1, 1 resimden 1.
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 2, 1 resimden 1.
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 4, 1 resimden 1.
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 6, 1 resimden 1.
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
  8. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 8, 1 resimden 1.
    • Use a screwdriver to remove the two 2.3mm PH00 screws on the processor fan.
  9. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 9, 1 resimden 1.
    • Use a PH0 screwdriver to loosen the 4 captured screws on the heat sink assembly.
  10. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: adım 10, 1 resimden 1.
    • Remove the processor fan and heat sink assembly.
Sonuç
Muhammad Erchid
1.051 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Leahy Fall 2018 USF Tampa, Team S1-G6, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 16
Her zaman: 267
