Ana içeriğe geç
Dell Inspiron 11-3138 Memory Modules Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3138 Memory Modules Replacement, Popping up the Memory Module: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before Working Inside Your Computer" After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 11-3138 Memory Modules Replacement, Removing the Memory Module: adım 2, 2 resimden 1. Dell Inspiron 11-3138 Memory Modules Replacement, Removing the Memory Module: adım 2, 2 resimden 2.
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 11-3138 Memory Modules Replacement, Aligning the Notch: adım 3, 1 resimden 1.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 11-3138 Memory Modules Replacement, Securing the Memory Module: adım 4, 1 resimden 1.
    • Slide the memory module firmly into the connector at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Sonuç
Terrence15
79.243 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 254
