Ana içeriğe geç
Dell Inspiron 11-3147 CMOS Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: adım 1, 2 resimden 1. Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: adım 1, 2 resimden 2.
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Using a plastic spudger, gently press under the battery to lift it up and out.
  3. Dell Inspiron 11-3147 CMOS Battery Replacement: adım 3, 1 resimden 1.
    • Remove the CMOS Battery
Sonuç
William Brum
737 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 37
Her zaman: 3,054
