Ana içeriğe geç
Dell Inspiron 11-3147 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3147 RAM Replacement, RAM: adım 1, 2 resimden 1. Dell Inspiron 11-3147 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 11-3147 RAM Replacement: adım 2, 2 resimden 2.
    • Place finger nails on both of the little metal tabs that are located on shorter sides of the Ram board.
    • Pull tabs outward and away from the Ram card. This will detach the card from the computer and allow removal.
  3. Dell Inspiron 11-3147 RAM Replacement: adım 3, 1 resimden 1.
    • Carefully remove the RAM to ensure no other components get damaged.
    • Replace with a new RAM card the exact way it came out, with the the shiny metallic part of the card placed inside black insert as shown in the picture.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
William Brum
737 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 1,275
