Ana içeriğe geç
Dell Inspiron 11-3147 Replace the Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Replace the Battery Replacement: adım 2, 1 resimden 1.
    • The 4mm battery screws can be removed with a philips head #0 screw driver. All the screws that must be removed are shown in the attached pictures.
    • Place screws close by in a safe place such as a magnetic board or cup so they are ready and accounted for when you begin reassembly.
  3. Dell Inspiron 11-3147 Replace the Battery Replacement: adım 3, 1 resimden 1.
    • Once the screws have been removed the battery may then be simply removed by hand and replaced.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
William Brum
737 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 2,516
