Giriş
In this guide, you will be replacing the battery to your Dell Inspiron. When finished, you should understand how to dissemble the back panel and remove the battery.
Neye ihtiyacın var
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
Bir başkası bu kılavuzu tamamladı.
