Ana içeriğe geç
Dell Inspiron 11-3162 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3162 Display Assembly Replacement, Remove the Screw: adım 1, 1 resimden 1.
  2. Dell Inspiron 11-3162 Display Assembly Replacement, Lifting the Display Cable: adım 2, 1 resimden 1.
    • Slide and lift the display-cable bracket off the system board.
  3. Dell Inspiron 11-3162 Display Assembly Replacement, Open the Latch: adım 3, 2 resimden 1. Dell Inspiron 11-3162 Display Assembly Replacement, Open the Latch: adım 3, 2 resimden 2.
    • Open the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 11-3162 Display Assembly Replacement, Open the Palm Rest: adım 4, 1 resimden 1.
    • Open the palm rest and keyboard assembly at an angle.
  5. Dell Inspiron 11-3162 Display Assembly Replacement, Remove the Screws: adım 5, 1 resimden 1.
    • Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
  6. Dell Inspiron 11-3162 Display Assembly Replacement, Lifting the Assemblies: adım 6, 1 resimden 1.
    • Slide and lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 11-3162 Display Assembly Replacement, Placing the Display Assembly: adım 7, 1 resimden 1.
    • Place the NEW display assembly on a flat and clean surface.
  8. Dell Inspiron 11-3162 Display Assembly Replacement, Align the Screw Holes: adım 8, 1 resimden 1.
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  9. Dell Inspiron 11-3162 Display Assembly Replacement, Replace the Screws: adım 9, 1 resimden 1.
    • Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
  10. Dell Inspiron 11-3162 Display Assembly Replacement, Securing the Cable: adım 10, 1 resimden 1.
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  11. Dell Inspiron 11-3162 Display Assembly Replacement, Sliding the Display Cable: adım 11, 1 resimden 1.
    • Slide the display-cable bracket into the slot on the palm rest and keyboard assembly.
  12. Dell Inspiron 11-3162 Display Assembly Replacement, Align the Screw Hole: adım 12, 1 resimden 1.
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  13. Dell Inspiron 11-3162 Display Assembly Replacement, Replace the Screw: adım 13, 1 resimden 1.
    • Replace the screw that secures the display-cable bracket to the system board.
Sonuç
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 538
