Ana içeriğe geç
Dell Inspiron 11-3162 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3162 Motherboard Replacement, Back Cover Removal: adım 1, 2 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement, Back Cover Removal: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Motherboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Motherboard Replacement: adım 4, 3 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement: adım 4, 3 resimden 2. Dell Inspiron 11-3162 Motherboard Replacement: adım 4, 3 resimden 3.
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Motherboard Replacement, Battery: adım 5, 2 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement, Battery: adım 5, 2 resimden 2.
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Motherboard Replacement: adım 6, 3 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement: adım 6, 3 resimden 2. Dell Inspiron 11-3162 Motherboard Replacement: adım 6, 3 resimden 3.
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 Motherboard Replacement, Wireless WLAN Card: adım 7, 2 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement, Wireless WLAN Card: adım 7, 2 resimden 2.
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 Motherboard Replacement: adım 8, 2 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement: adım 8, 2 resimden 2.
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 Motherboard Replacement: adım 9, 1 resimden 1.
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
    • Use the tweezers to unplug the DC Jack.
  11. Dell Inspiron 11-3162 Motherboard Replacement: adım 11, 1 resimden 1.
    • Use the tweezers unplug the Speaker Cable.
  12. Dell Inspiron 11-3162 Motherboard Replacement: adım 12, 1 resimden 1.
    • Use the tweezers to remove the CMOS Cable.
  13. Dell Inspiron 11-3162 Motherboard Replacement: adım 13, 1 resimden 1.
    • Use the tweezers to remove the Touchpad Cable.
  14. Dell Inspiron 11-3162 Motherboard Replacement: adım 14, 3 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement: adım 14, 3 resimden 2. Dell Inspiron 11-3162 Motherboard Replacement: adım 14, 3 resimden 3.
    • Use the phillips screwdriver with the PH0 to loosen the 4 screws and remove the orange plate.
  15. Dell Inspiron 11-3162 Motherboard Replacement: adım 15, 2 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement: adım 15, 2 resimden 2.
    • Use the phillips screwdriver with the PH00 head to unscrew the one 3mm screw. Then, remove the bracket.
  16. Dell Inspiron 11-3162 Motherboard Replacement: adım 16, 2 resimden 1. Dell Inspiron 11-3162 Motherboard Replacement: adım 16, 2 resimden 2.
    • Remove the keyboard cable.
  17. Dell Inspiron 11-3162 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the motherboard by gently lifting upwards from the edges.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 33
Her zaman: 2,369
