Ana içeriğe geç
Dell Inspiron 11-3164 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3164 Battery Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 11-3164 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 6 mm screws.
    • Remove the plastic cover to unveil the final screw holding the front and back frame together.
    • Remove this last screw of size 6mm with the J1 phillips head bit found in the approved iFixit toolkit.
  2. Dell Inspiron 11-3164 Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 11-3164 Battery Replacement: adım 2, 2 resimden 2.
    • Using your metal pry tool, slowly pry the two halves apart by gently moving your tool around the laptop . Once all the way around the top and bottom half will separate.
    • When pulling the laptops apart be careful to hold them together at first due to the sensitive ribbon cable inside.
    • Use your metal pry tool again to push the ribbon holding clip up and remove the ribbon cable.
  3. Dell Inspiron 11-3164 Battery Replacement: adım 3, 1 resimden 1.
    • Use the J1 screw driver bit from earlier and unscrew the three size 4mm battery screws.
  4. Dell Inspiron 11-3164 Battery Replacement: adım 4, 1 resimden 1.
    • While using one hand to hold the laptop grab the power wire with the other hand and pull it out of it's port.
    • Carefully remove the battery pack from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Kendziora
781 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 287
