Ana içeriğe geç
Dell Inspiron 11-3164 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3164 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Dell Inspiron 11-3164 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
    • With a metal spudger, remove the plastic cover to unveil the final screw.
    • With the J1 Phillips head bit, remove remaining 60 mm screw.
  2. Dell Inspiron 11-3164 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 11-3164 Keyboard Replacement: adım 2, 2 resimden 2.
    • With a metal spudger, pry apart the bottom cover working around the edges.
    • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With tweezers, disconnect the USB/Audio circuit board cable.
    • Place the bottom cover off to the side.
  3. Dell Inspiron 11-3164 Keyboard Replacement: adım 3, 1 resimden 1.
    • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
  4. Dell Inspiron 11-3164 Keyboard Replacement: adım 4, 1 resimden 1.
    • With tweezers, disconnect the battery cable.
    • Remove the battery pack.
  5. Dell Inspiron 11-3164 Keyboard Replacement: adım 5, 3 resimden 1. Dell Inspiron 11-3164 Keyboard Replacement: adım 5, 3 resimden 2. Dell Inspiron 11-3164 Keyboard Replacement: adım 5, 3 resimden 3.
    • Remove the M2 x 3mm bracket screw.
    • Remove the metal bracket.
    • With tweezers, detach the white and black antenna cables connected to the Wireless WLAN Card.
    • Remove the Wireless WLAN Card.
  6. Dell Inspiron 11-3164 Keyboard Replacement: adım 6, 1 resimden 1.
    • With tweezers, unplug the CMOS battery.
    • With tweezers, detach the CMOS battery.
  7. Dell Inspiron 11-3164 Keyboard Replacement: adım 7, 2 resimden 1. Dell Inspiron 11-3164 Keyboard Replacement: adım 7, 2 resimden 2.
    • With tweezers, unplug the DC Jack cable.
    • With the Philips #0 Screwdriver, loosen the M2 x 3mm screw.
    • With tweezers, detach the DC Jack.
  8. Dell Inspiron 11-3164 Keyboard Replacement: adım 8, 2 resimden 1. Dell Inspiron 11-3164 Keyboard Replacement: adım 8, 2 resimden 2.
    • With tweezers, disconnect the speaker cable.
    • With tweezers, detach the speaker.
  9. Dell Inspiron 11-3164 Keyboard Replacement: adım 9, 2 resimden 1. Dell Inspiron 11-3164 Keyboard Replacement: adım 9, 2 resimden 2.
    • With the Philips #0 Screwdriver, unbolt the M2 x 3mm screw.
    • With tweezers, disconnect the display cable.
  10. Dell Inspiron 11-3164 Keyboard Replacement: adım 10, 3 resimden 1. Dell Inspiron 11-3164 Keyboard Replacement: adım 10, 3 resimden 2. Dell Inspiron 11-3164 Keyboard Replacement: adım 10, 3 resimden 3.
    • With the Philips #0 Screwdriver, unfasten the 2 - M2.5 x 5mm left and right hinge screws.
    • With the Philips #0 Screwdriver, unhinge the 2 - M2.5 x 5mm display cable bracket screw.
    • With tweezers, remove the LCD screen.
  11. Dell Inspiron 11-3164 Keyboard Replacement: adım 11, 1 resimden 1.
    • With the Philips #0 Screwdriver, loosen the 4 screws supporting the copper plate.
    • With tweezers, remove the copper plate.
  12. Dell Inspiron 11-3164 Keyboard Replacement: adım 12, 2 resimden 1. Dell Inspiron 11-3164 Keyboard Replacement: adım 12, 2 resimden 2.
    • With tweezers, disconnect the keyboard cable.
    • With tweezers, disconnect the touchpad cable.
    • With the Philips #00 Screwdriver, loosen the four (4) M2 x 2mm screws.
    • Gently remove the mouse touchpad. The fixer is left with the palm-rest and keyboard assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Kendziora
781 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 300
