Ana içeriğe geç
Dell Inspiron 11-3168 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3168 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 11-3168 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Hard Drive Replacement: adım 2, 3 resimden 1. Dell Inspiron 11-3168 Hard Drive Replacement: adım 2, 3 resimden 2. Dell Inspiron 11-3168 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Hard Drive Replacement: adım 3, 2 resimden 1. Dell Inspiron 11-3168 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Hard Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron 11-3168 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Hard Drive Replacement: adım 5, 3 resimden 1. Dell Inspiron 11-3168 Hard Drive Replacement: adım 5, 3 resimden 2. Dell Inspiron 11-3168 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Remove the battery.
  6. Dell Inspiron 11-3168 Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. Dell Inspiron 11-3168 Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Unscrew the two 7.5 mm Phillips #00 screws.
  7. Dell Inspiron 11-3168 Hard Drive Replacement: adım 7, 3 resimden 1. Dell Inspiron 11-3168 Hard Drive Replacement: adım 7, 3 resimden 2. Dell Inspiron 11-3168 Hard Drive Replacement: adım 7, 3 resimden 3.
    • Lift the hard drive out of the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 2,434
