Ana içeriğe geç
Dell Inspiron 11-3168 Screen Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3168 Screen Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 11-3168 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Screen Replacement: adım 2, 3 resimden 1. Dell Inspiron 11-3168 Screen Replacement: adım 2, 3 resimden 2. Dell Inspiron 11-3168 Screen Replacement: adım 2, 3 resimden 3.
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Screen Replacement: adım 3, 2 resimden 1. Dell Inspiron 11-3168 Screen Replacement: adım 3, 2 resimden 2.
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Screen Replacement: adım 4, 2 resimden 1. Dell Inspiron 11-3168 Screen Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Screen Replacement: adım 5, 3 resimden 1. Dell Inspiron 11-3168 Screen Replacement: adım 5, 3 resimden 2. Dell Inspiron 11-3168 Screen Replacement: adım 5, 3 resimden 3.
    • Remove the battery.
  6. Dell Inspiron 11-3168 Screen Replacement, Screen: adım 6, 3 resimden 1. Dell Inspiron 11-3168 Screen Replacement, Screen: adım 6, 3 resimden 2. Dell Inspiron 11-3168 Screen Replacement, Screen: adım 6, 3 resimden 3.
    • Carefully flip the laptop over so that the top case is facing up.
    • Remove the top case of the laptop by gently prying along the seam with a plastic opening tool.
  7. Dell Inspiron 11-3168 Screen Replacement: adım 7, 3 resimden 1. Dell Inspiron 11-3168 Screen Replacement: adım 7, 3 resimden 2. Dell Inspiron 11-3168 Screen Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to grip the tape that is holding down the display cable clip.
    • Gently unpeel the tape. This will release the clip that locks over the display connector socket.
    • Once unclipped, remove the display cable from the socket.
  8. Dell Inspiron 11-3168 Screen Replacement: adım 8, 3 resimden 1. Dell Inspiron 11-3168 Screen Replacement: adım 8, 3 resimden 2. Dell Inspiron 11-3168 Screen Replacement: adım 8, 3 resimden 3.
    • Find the smaller ZIF connector. Using tweezers, carefully lift the black flap on the connector to release the ribbon cable.
  9. Dell Inspiron 11-3168 Screen Replacement: adım 9, 2 resimden 1. Dell Inspiron 11-3168 Screen Replacement: adım 9, 2 resimden 2.
    • Disconnect the webcam module located at the top of the monitor.
  10. Dell Inspiron 11-3168 Screen Replacement: adım 10, 2 resimden 1. Dell Inspiron 11-3168 Screen Replacement: adım 10, 2 resimden 2.
    • Lift and remove the display screen from the top case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
how much did this display cost?
Ibrahim Ahmed Mohamed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 750
