Ana içeriğe geç
Dell Inspiron 1100 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1100 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Dell Inspiron 1100 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Dell Inspiron 1100 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Remove the plastic face plate from the laptop using the iFixit Plastic Opening Tool.
    • Start by inserting the iFixit Plastic Opening Tool into the groove on the right side of the face plate.
    • This step does require some force. Be careful to not bend or break the plastic face plate.
  2. Dell Inspiron 1100 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 1100 Keyboard Replacement: adım 2, 2 resimden 2.
    • Remove the four 3mm Phillips #0 screws securing the keyboard.
  3. Dell Inspiron 1100 Keyboard Replacement: adım 3, 1 resimden 1.
    • Lift up the keyboard to expose the ribbon header on the motherboard.
    • Be careful as the keyboard can only move a little ways from the surface of the laptop and is easily damaged.
  4. Dell Inspiron 1100 Keyboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 1100 Keyboard Replacement: adım 4, 2 resimden 2.
    • Grip the ribbon on its hard plastic connector, and pull the ribbon and its connector out of the motherboard header.
    • Do not pull on the ribbon itself, as this may cause internal damage to the connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alexander Pacheco
628 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 UMass Dartmouth, Team 3-3, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G3
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 9
Son 30 gün: 14
Her zaman: 640
