Ana içeriğe geç
Dell Inspiron 1100 Wireless Card Replacement
Neye ihtiyacın var
    1. Dell Inspiron 1100 Wireless Card Replacement, Wireless Card: adım 1, 2 resimden 1. Dell Inspiron 1100 Wireless Card Replacement, Wireless Card: adım 1, 2 resimden 2.
      • Unscrew the one Phillips #0 screw at the bottom of the panel and remove the panel.
      • The screw does not separate from the cover. Be sure the screw is completely unscrewed before using force to remove the cover.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 1100 Wireless Card Replacement: adım 2, 2 resimden 1. Dell Inspiron 1100 Wireless Card Replacement: adım 2, 2 resimden 2.
      • Unscrew the two 3mm Phillips #0 screws located on the card.
      • Be careful, as these screws are easy to strip.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 1100 Wireless Card Replacement: adım 3, 2 resimden 1. Dell Inspiron 1100 Wireless Card Replacement: adım 3, 2 resimden 2.
      • Pull the white plastic tab on top of the card straight up to remove the card.
      • This step requires some light force. Be sure the screws from the previous step have been removed.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 1100 Wireless Card Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use blunt nose tweezers to remove the power cable from the wireless card.
      • Make sure the tweezers are only gripping the head of the power cable and not any part of the wireless card, as this may damage the card.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Alexander Pacheco
628 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 UMass Dartmouth, Team 3-3, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G3
3 Üyeler
60 adet Kılavuz yazıldı
2Kılavuz Yorumları
I believe that is a phone modem, not a wireless card. Might be wrong though.
George A. - Yanıt Paylaş
i think your right as dell 1100 dont have a wifi slot only can use usb or pcmcia card
Conner Peden - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 30
Son 30 gün: 44
Her zaman: 1,071
