Ana içeriğe geç
Dell Inspiron 1122 M102z Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1122 M102z Display Assembly Replacement, Disconnecting the Mini-Card Antenna Cables: adım 1, 1 resimden 1.
    • Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 1122 M102z Display Assembly Replacement, Dislodging the Mini-Card Antenna Cables: adım 2, 1 resimden 1.
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Dell Inspiron 1122 M102z Display Assembly Replacement, Disconnecting the Display Cable: adım 3, 1 resimden 1.
    • Disconnect the display cable from the system board connector.
  4. Dell Inspiron 1122 M102z Display Assembly Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 1122 M102z Display Assembly Replacement, Removing the Display Assembly: adım 5, 1 resimden 1.
    • Lift and remove the display assembly off the computer base.
  6. Dell Inspiron 1122 M102z Display Assembly Replacement, Placing the Display Assembly: adım 6, 1 resimden 1.
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron 1122 M102z Display Assembly Replacement, Connecting the Display Cable: adım 7, 1 resimden 1.
    • Connect the display cable to the system board connector.
  8. Dell Inspiron 1122 M102z Display Assembly Replacement, Routing the Mini-Card Cables: adım 8, 1 resimden 1.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  9. Dell Inspiron 1122 M102z Display Assembly Replacement, Conencting the Mini-Card Antenna Cables: adım 9, 1 resimden 1.
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Sonuç
Terrence15
79.131 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.986 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 129
