Ana içeriğe geç
Dell Inspiron 11z 1110 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11z 1110 Memory Module Replacement, Popping up the Memory Module: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  2. Dell Inspiron 11z 1110 Memory Module Replacement, Removing the Memory Module: adım 2, 2 resimden 1. Dell Inspiron 11z 1110 Memory Module Replacement, Removing the Memory Module: adım 2, 2 resimden 2.
    • Remove the memory module from the memory module connector.
  3. Dell Inspiron 11z 1110 Memory Module Replacement, Align the Notch: adım 3, 1 resimden 1.
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  4. Dell Inspiron 11z 1110 Memory Module Replacement, Pressing down the Memory Module: adım 4, 1 resimden 1.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Sonuç
Terrence15
79.243 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 259
