Giriş
In this guide, we will show you how to remove and replace the Memory Module.
Neye ihtiyacın var
Loosen the captive screw that secures the memory-module cover to the computer base.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch in the memory module with the tab in the memory-module connector.
Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
Tighten the screw that secures the memory-module cover to the computer base.
