Ana içeriğe geç
Dell Inspiron 11z-1121 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Mini-Card Cables: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 11z-1121 Display Assembly Replacement, Dislodge the Cables: adım 2, 1 resimden 1.
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Display Cable: adım 3, 1 resimden 1.
    • Disconnect the display cable from the system board connector.
  4. Dell Inspiron 11z-1121 Display Assembly Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 11z-1121 Display Assembly Replacement, Lifting and Removing the Display Assembly: adım 5, 1 resimden 1.
    • Lift and remove the display assembly off the computer base.
  6. Dell Inspiron 11z-1121 Display Assembly Replacement, Replace the Screws: adım 6, 1 resimden 1.
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Display Cable: adım 7, 1 resimden 1.
    • Connect the display cable to the system board connector.
  8. Dell Inspiron 11z-1121 Display Assembly Replacement, Routing the Cables: adım 8, 1 resimden 1.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  9. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Cables: adım 9, 1 resimden 1.
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Sonuç
Terrence15
79.555 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 295
