Ana içeriğe geç
Dell Inspiron 11z-1121 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: adım 2, 2 resimden 1. Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: adım 2, 2 resimden 2.
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Hard Drive Replacement: adım 3, 2 resimden 1. Dell Inspiron 11z-1121 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Hard Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron 11z-1121 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • The hard drive will be a silver rectangle. Slide the hard drive to the right to remove.
    • To be safe, make sure you either wear an anti-static wrist band, or rub your hands against a metal object to remove any static.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandan Eng
143 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Nance Fall 2016 USF Tampa, Team 1-5, Nance Fall 2016 üyesi
USFT-NANCE-F16S1G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 2,042
