Ana içeriğe geç
Dell Inspiron 11z-1121 Memory Modules Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11z-1121 Memory Modules Replacement, Loosen the Screw: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 11z-1121 Memory Modules Replacement, Lifting the Memory-Module Cover: adım 2, 1 resimden 1.
    • Lift the memory-module cover off the computer base.
  3. Dell Inspiron 11z-1121 Memory Modules Replacement, Popping up the Memory Module: adım 3, 1 resimden 1.
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  4. Dell Inspiron 11z-1121 Memory Modules Replacement, Removing the Memory Module: adım 4, 1 resimden 1.
    • Remove the memory module from the memory-module connector.
  5. Dell Inspiron 11z-1121 Memory Modules Replacement, Align the Notch: adım 5, 1 resimden 1.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  6. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Memory Module: adım 6, 2 resimden 1. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Memory Module: adım 6, 2 resimden 2.
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
  7. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Tabs: adım 7, 1 resimden 1.
    • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  8. Dell Inspiron 11z-1121 Memory Modules Replacement, Tighten the Screw: adım 8, 1 resimden 1.
    • Tighten the screw that secures the memory-module cover to the computer base.
Sonuç
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 179
