Ana içeriğe geç
Dell Inspiron 11z-1121 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11z-1121 RAM Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 11z-1121 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 RAM Replacement, RAM: adım 2, 2 resimden 1. Dell Inspiron 11z-1121 RAM Replacement, RAM: adım 2, 2 resimden 2.
    • With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
    • Using your fingers, remove the access door to expose the memory card
  3. Dell Inspiron 11z-1121 RAM Replacement: adım 3, 2 resimden 1. Dell Inspiron 11z-1121 RAM Replacement: adım 3, 2 resimden 2.
    • To access the memory card, push out the lashes on the left and the right of the memory card.
    • To remove the memory card, use your fingers to pull it out with the lashes still stretched out.
Sonuç
Ekip
USF Tampa, Team 1-5, Nance Fall 2016 USF Tampa, Team 1-5, Nance Fall 2016 üyesi
USFT-NANCE-F16S1G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 514
