Giriş
In this guide, we will show you how to remove the Display Assembly.
Neye ihtiyacın var
Disconnect the display ground wire from the EMI shield by unscrewing the captive screw.
Remove the four M2.5 x 5-mm screws (labeled "M2.5x5") that secure the EMI shield to the system board.
Pull the EMI shield out of the computer baseby rotating the front upwards then lifting to release the retention tabs from the retention-tab slots.
Disconnect the attached antenna cable from the Mini PCI card.
Close the display.
From the bottom of the computer, remove the two M2.5 x 5-mm screws labeled "D."
From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
Carefully remove the Mini PCI card antenna cable and the display cables from their routing guides.
