Ana içeriğe geç
Dell Inspiron 13 7368 Memory Modules Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13 7368 Memory Modules Replacement, Disconnecting the Battery Cable: adım 1, 1 resimden 1.
  2. Dell Inspiron 13 7368 Memory Modules Replacement, Remove the Screws: adım 2, 1 resimden 1.
    • Remove the screws that secure the battery to the palm-rest assembly.
  3. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Battery: adım 3, 1 resimden 1.
    • Lift the battery off the palm-rest assembly.
    • Press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 13 7368 Memory Modules Replacement, Align the Screw Holes: adım 5, 1 resimden 1.
    • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
  5. Dell Inspiron 13 7368 Memory Modules Replacement, Replace the Screws: adım 6, 1 resimden 1.
    • Replace the screws that secure the battery to the palm-rest assembly.
  6. Dell Inspiron 13 7368 Memory Modules Replacement, Connecting the Battery Cable: adım 7, 1 resimden 1.
    • Connect the battery cable to the system board.
  7. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Mylar: adım 8, 1 resimden 1.
  8. Dell Inspiron 13 7368 Memory Modules Replacement, Popping up the Memory Module: adım 9, 1 resimden 1.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  9. Dell Inspiron 13 7368 Memory Modules Replacement, Removing the Memory Module: adım 10, 2 resimden 1. Dell Inspiron 13 7368 Memory Modules Replacement, Removing the Memory Module: adım 10, 2 resimden 2.
    • Remove the memory module from the memory-module slot.
  10. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Mylar: adım 11, 1 resimden 1.
    • Lift the Mylar to access the memory-module slot.
  11. Dell Inspiron 13 7368 Memory Modules Replacement, Align the Notch: adım 12, 1 resimden 1.
    • Align the notch on the memory module with the tab on the memory-module slot.
  12. Dell Inspiron 13 7368 Memory Modules Replacement, Sliding the Memory Module: adım 13, 1 resimden 1.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Bitiş Çizgisi
Terrence15
79.091 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 430
