Giriş
In this guide, we will show you how to remove and replace the Memory Modules.
Neye ihtiyacın var
Remove the screws that secure the battery to the palm-rest assembly.
Press and hold the power button for five seconds to ground the system board.
Align the screw holes on the battery with the screw holes on the palm-rest assembly.
Replace the screws that secure the battery to the palm-rest assembly.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
NOTE: If you do not hear the click, remove the memory module and reinstall it.
