Ana içeriğe geç
Dell Inspiron 13 7378 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13 7378 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 13 7378 Battery Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Battery Replacement: adım 3, 3 resimden 1. Dell Inspiron 13 7378 Battery Replacement: adım 3, 3 resimden 2. Dell Inspiron 13 7378 Battery Replacement: adım 3, 3 resimden 3.
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the four screws from the battery using a Phillips #00 screwdriver.
  5. Dell Inspiron 13 7378 Battery Replacement: adım 5, 2 resimden 1. Dell Inspiron 13 7378 Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery's black connector from the motherboard.
  6. Dell Inspiron 13 7378 Battery Replacement: adım 6, 2 resimden 1. Dell Inspiron 13 7378 Battery Replacement: adım 6, 2 resimden 2.
    • Remove the battery from the laptop.
Sonuç
Replace the back cover to complete the process.
6 farklı kişi bu kılavuzu tamamladı.
Michelle Reyes
282 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022 üyesi
GCC-SAKNEE-S22S1G3
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 29
Son 30 gün: 155
Her zaman: 4,711
