Ana içeriğe geç
Dell Inspiron 13 7378 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13 7378 RAM Replacement, Back Cover: adım 1, 1 resimden 1.
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 13 7378 RAM Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 RAM Replacement: adım 3, 3 resimden 1. Dell Inspiron 13 7378 RAM Replacement: adım 3, 3 resimden 2. Dell Inspiron 13 7378 RAM Replacement: adım 3, 3 resimden 3.
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 RAM Replacement, RAM: adım 4, 3 resimden 1. Dell Inspiron 13 7378 RAM Replacement, RAM: adım 4, 3 resimden 2. Dell Inspiron 13 7378 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • To remove a RAM stick, gently pull apart the metal tabs on either side of the stick.
    • Carefully grasp the stick on its side and pull it out.
    • The plastic sheet covering the RAM compartment depicts the process.
  5. Dell Inspiron 13 7378 RAM Replacement: adım 5, 1 resimden 1.
    • When inserting the new stick, make sure that the gap on in the stick aligns with the gap in the slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emma Simon
165 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022 üyesi
GCC-SAKNEE-S22S1G3
5 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 863
